Two-Platen
Injection Molding Machines
Large injection molding machines from 550 to 6,500 tonnes for automotive, industrial, logistics, and deep-cavity production.
Choose a two-platen machine for the highest clamping force in the smallest footprint, the best mold support for large tools, and the widest tonnage range from a single manufacturer.
Two-Platen Injection Molding Machines for High Tonnage in a Compact Footprint
A two-platen injection molding machine uses only two main platens, a fixed platen and a moving platen, instead of the three found in toggle machines. Clamping force is generated by hydraulic cylinders acting directly on the tie bars, with a mechanical or hydraulic locking mechanism holding the mold closed during injection.
The absence of a rear platen and toggle linkage means a two-platen machine delivers the same clamping force as a toggle machine in a significantly shorter overall length, with uniform force distribution across the entire mold face and greater daylight relative to machine size. Two-platen sits alongside Chen Hsong’s full injection molding machine range of hydraulic toggle, all-electric, hybrid, vertical, and high-speed packaging machines.
20,000/yr
Machines Produced
200+
Patented Technologies
120+
Service Locations
iChen™
Smart Factory Platform
Connected, intelligent production
Every Chen Hsong machine is ready for smart manufacturing through the iChen™ platform. iChen™ Smart Factory connects machines, automation, and production systems into a complete MES solution. iChen™ Cloud provides real-time monitoring, quality tracking, and data-driven operations across your entire fleet. iChen™ AI Molder applies AI-driven process intelligence to optimize molding parameters, reduce defects, and stabilize output, without relying on operator experience alone.
As a global injection molding machine supplier with 120+ service locations, Chen Hsong supports manufacturers in automotive, packaging, electronics, medical, home appliance, and industrial production with machines, automation, and smart factory solutions.
Trusted Worldwide. Proven at Scale.
Chen Hsong’s true two-platen machines are trusted worldwide, with more than 1,000 units deployed globally. Customers include BYD, FAW, Haier, Midea, Gree, Arçelik, and tier-1 European automotive suppliers, running 24/7 for automotive parts, large appliance housings, logistics crates and pallets, IBC containers, and pipe fittings.
Chen Hsong pioneered China’s first true two-platen in 2007 and in 2014 launched the 6,500-tonne SM-TP, Asia’s first servo-driven two-platen at that scale. The platform is protected by multiple international patents, with Precision Hydraulics™ delivering up to 80% energy saving and NON-STOP™ reliability supporting 24/7 production.
TP-SMART
Smart Two-Platen. Modular by Design.
Modular clamping unit with multiple injection carriages. 4th-generation servo drive. Smart, accessible two-platen for mid-to-large tonnage.
550 -
1700T
Two-Platen
Servo Hydraulic
SM-TP
Massive Clamping Force. Compact Footprint.
True two-platen with 13 clamping units × 14 injection units mix-and-match. 4 patented technologies. The heavyweight platform for the largest applications.
700 -
6500T
Two-Platen
Servo Hydraulic
Global Customers
01SM-TP or TP-SMART, which model should I choose?
Both share Chen Hsong’s patented two-platen technology, NON-STOP™ reliability, and Precision Hydraulics™. The SM-TP (700–6,500T) is the heavyweight platform with 13 clamping units × 14 injection units in a mix-and-match system, including 1,000-ton, 2,000-ton, 3,000-ton, 4,000-ton, and 6,500-ton large injection molding machines.
Choose it for maximum tonnage, the largest molds, and the widest configuration flexibility. The TP-SMART (550–1,700T) is the smart, modular two-platen with 4th-generation servo drive. Choose it for mid-to-large tonnage where intelligent control and modular flexibility matter more than ultra-high tonnage.
A toggle machine uses three platens and a toggle linkage to generate clamping force mechanically. A two-platen machine uses only two platens, with hydraulic cylinders acting directly on the tie bars.
The key practical differences: two-platen machines deliver the same clamping force in a significantly shorter overall length, provide more uniform force distribution across the mold face, and offer greater daylight (mold opening distance) relative to machine size.
This makes two-platen the standard choice when floor space is limited but large molds, high tonnage (typically 500+ tonnes), or deep-draw parts are required. Toggle remains the better value choice for general-purpose production at smaller tonnages.
Two-platen machines are the standard choice for large-part, high-tonnage production where toggle machines hit their practical limits. Typical applications include automotive bumpers, dashboards, door panels, and large interior or exterior parts; logistics crates, pallets, IBC containers, and bulk containers running 24/7; home appliance components such as washing machine drums, refrigerator liners, and large air conditioner or television housings; and industrial and infrastructure products including pipe fittings, water tanks, electrical enclosures, and large structural components.
As a general rule, two-platen becomes the better choice above 500 tonnes, particularly when mold size, mold weight, or floor space constraints make a toggle machine impractical, or when parts require long opening stroke and large daylight relative to machine size.
All Chen Hsong two-platen machines support the iChen™ ecosystem: iChen™ Smart Factory for MES and automation integration, iChen™ Cloud for real-time production monitoring and data analytics, and iChen™ AI Molder for AI-driven process optimization.
Standard IoT connectivity and OPC UA support are available across the range.
Chen Hsong supports customers through 120+ service locations worldwide. Large-tonnage two-platen machines are major capital investments running 24/7, so reliable after-sales is critical.
Standard coverage includes installation, commissioning, operator training, preventive maintenance, spare parts supply, and remote diagnostics through the iChen™ platform.
Service contracts and extended warranty options are available. For customers in China, the 24-hour “服务易” hotline (400-930-0026) provides round-the-clock response.
Talk to our AI Assistant
Have a question that is not covered in the FAQ? Our AI assistant can help you find answers, products, or the right next step.
Start a chat
Why Manufacturers Choose Chen Hsong
Founded in 1958 Icon
Founded 1958
Over six decades of injection molding expertise
85+ Countries Icon
85+ Countries
Machines operating across major industrial markets worldwide
900,000 m2 Icon
1,000,000 m2
Five R&D and production facilities with full vertical integration
1,000,000+ Machines Icon
1,000,000+
Injection molding machines delivered and in operation
200+ Patents Icon
200+ Patents
Patented technologies plus 20+ software IP
Up To 80 Icon
Up to 80%
Energy savings with servo-hydraulic technology
Euromap Icon
EUROMAP & SPI
Region-specific machine configurations for global mold standards
120+ Locations Icon
120+ Locations
Global installation, training, maintenance, and technical support
