Automotive Injection Molding Applications from Chen Hsong
Automotive injection molding at Chen Hsong covers bumpers, door panels, interior trims, lamp lenses, radiator tanks and under-bonnet components. BYD and FAW Group are among the manufacturers running Chen Hsong machines, with exterior body parts typically calling for 550 to 6,500 tonnes of clamping force.
Why Two-Platen Dominates Automotive Molding
A bumper mold is large, heavy and deep. Two-platen machines carry it in a shorter footprint than a toggle machine of equal force, spread clamping load evenly across the platen face, and give the daylight that deep draws need. Chen Hsong has more than 1,000 two-platen units in service worldwide. Lamp assemblies are a different problem again: a clear lens and a coloured housing molded in one cycle on multi-material machines, where rotary platen positioning accuracy decides whether the bond line comes out clean or bleeds.
Consistency Across a Model Programme
Programmes run for years, and process drift eventually shows up as a warranty claim. Precision Hydraulics™ holds ±0.05% repeatability on the critical axes, NON-STOP™ is built around uninterrupted running, and iChen™ AI Molder monitors and corrects parameters shot by shot rather than waiting for a technician to notice. More on the automotive injection molding solutions page.
Plastic Injection Molding of Car Seat Cushions
Seat Cushion Durability and function require dependability in all phases of plastic injection parts manufacturing. Plastic injection molding of seat cushions is no exception. A sturdy construction, with an ergonomic knurled surface is a requisite for our client. The JM650-C3-SVP/2 plastic injection machine is fully capable of meeting these requirements. 16 machines are presently producing […]
Plastic Injection Molding of Car Radiator Tank with PA+GF Resin
Car Radiator Tank Automotive radiator designs have changed over the years, and recently there’s been a trend towards using radiator tanks made mostly from plastic instead of metal. Plastic injection molded automotive radiators are cheaper to produce and easier to install than their metal counterparts. Because of the harsh operating conditions, the plastic radiator tanks […]
High-Gloss Automotive Buttons / Injection Molding
High-Gloss Automotive Buttons One of our customers in Wenzhou, Zhejiang Province employs more than 200 of our JM128-MK6 High-Speed Toggle Injection Molding Machines to manufacture gloss finish automotive buttons from PC resin in 4 cavities with a shot weight of 8.7g at a thickness of 1.15mm. The cycle time in semi-automatic mode is only 24.5s […]
Employing the EM180-SVP/3+ for Injection Molding of TVP Automotive Cup Holders
TPV Cup Holders Our Toggle Injection Molding EM180-SVP/3+ Machine uses a Beckhoff CBmold300 controller on an EtherCAT digital main bus with the SVP/3 Servo-Drive applying a clamping force of 180 tons to manufacture automotive cup holders in 2 cavities from Exxon Mobil TPV resin. These are produced on a fully-automatic cycle time of 68s at […]
Injection Molding Honda Side Panels with the JM1000 Series
Honda Side Panels drafted by Iris Our customer in Hubei Province is employing a Multi-Pump Combination Hydraulic Power System to manufacture parts for Honda automotive. Using 10 of our Toggle-Type JM1000-C3-SVP/2 Injection Molding Machines, our customer manufactures pairs of polypropylene Honda side panels to a thickness of 2mm in fully automatic mode with a cycle […]
Injection Molding of Car Glove Compartments
Car Storage Compartment Meeting the ever-increasing demands of the industrial and automotive industry, our client in the High-tech Industrial Development Zone of Changchun is keeping ahead of the competition with the fully automatic JM-1400-C3-SVP/2 plastic injection molding machine series. 10 machines are producing these high-quality PP / PE plastic glove compartment storage boxes at the […]
Injection molding left and right shroud outer plates for the automotive industry
Left & Right Shroud Outer Plates Excellent uniformity and a superior finish are required on this automotive component and these standards are consistently met with the JM1450-C2 C2 plastic injection molding machine. Advanced technological innovations, an Ai 11 controller, and precise robotic operations are combined for the fully automated manufacturing of high-quality left and right […]
Fully Automatic Plastic Injection Molding of ABS front door exterior trims
Front Door Exterior Trims More than 30 of our EM480 SVP2 Injection Molding Machines are working full-time in Shunyi District, Beijing to manufacture automotive front door exterior trims. Operating in fully automatic mode with a cycle time of 60 seconds to complete plastic injection of 2 front door trims, and with the help of a […]
Production of ABS Car Control Panel Shields
Car Control Panel ABS Shields The intricacy of multi-surfaced components such as control panel car shields demands strict parameters during manufacturing to guarantee an absolute minimum of defects during production. The EM150-SVP/2 Plastic Injection Molding Machine with its Ai 02 controller and 150 ton clamping force gives the consistent quality expected in all its operations. […]
Fully Automatic Plastic Injection Molding of Car Rear Door Map Pockets
Rear Door Map Pockets 30 of our JM650-C3-SVP/2 Injection Molding Machines are working full-time in Shunyi District, Beijing to manufacture car rear door map pockets. Operating in fully automatic mode, two rear door map pockets are completed in a cycle time of 35 seconds as a robotic arm offloads the parts, delivering high quality parts […]
