The C-Pack is Chen Hsong’s dedicated pail and bucket injection molding machine, built on the proven MK6.6 platform and optimised specifically for olefin resin processing. Specialised PP screw with 25:1 L/D ratio delivers fast plasticising speed with excellent mixing and melt quality for acid-resistant, anti-oxidant, and high-performance industrial pails. High-speed wear-resistant hydraulic motor provides higher torque for reliable high-speed recovery and consistent melt over years of production.
A complete pail production solution in one package. Chen Hsong configures each C-Pack with matched servo-driven take-out robots, automated loading systems, dehumidifiers, granulators, mold temperature controllers, chillers, and conveyor belts, all sized to the specific machine model. Specially-strengthened clamping unit designed through advanced stress simulation for minimal deformation and consistent product quality. Large opening stroke accommodates deep cavity pail molds. Balanced dual injection cylinders ensure precise nozzle alignment and stable injection. No integration guesswork, no mismatched auxiliaries, one supplier for the entire line.
The C-Pack is purpose-built for pail and bucket production on the proven MK6.6 platform. It features a specialised PP screw with 25:1 L/D ratio optimised for olefin resins, a high-speed wear-resistant hydraulic motor for fast and durable plasticising, a specially-strengthened clamping unit with FEA-optimised rigidity, and long opening stroke for deep cavity molds.
Standard machines require aftermarket modifications to achieve similar performance on pail production. The C-Pack delivers it out of the box.
The C-Pack is designed for industrial and chemical pails, paint buckets, food-grade containers, lubricant containers, and other deep cavity PP products.
The specialised PP screw handles resins with anti-oxidant, anti-corrosion, and other performance additives used in chemical and industrial packaging.
The long opening stroke and strengthened clamping unit accommodate the deep cavity molds typical of pail production.
Yes. Chen Hsong configures each C-Pack with a matched smart manufacturing solution including servo-driven take-out robots, automated loading systems, dehumidifier/dryer combos, granulators, mold temperature controllers, chillers, storage hoppers, and conveyor belts.
Each auxiliary component is sized and matched to the specific C-Pack model for a complete turnkey production line.
The C-Pack is available in four models: JM328 (328T), JM488 (488T), JM658 (658T), and JM800 (800T). Tie bar spacing ranges from 660x660mm on the JM328 to 1020x1020mm on the JM800, accommodating a wide range of pail mold sizes.
