Packaging Injection Molding Applications from Chen Hsong
Packaging injection molding covers thin-wall food containers, lids, caps and closures, cosmetics packaging, PET preforms, industrial containers and in-mold labelling. Cycle times under three seconds are normal here, and yield at speed is what decides whether a part makes money.
Built for Thin-Wall Speed
High-speed packaging machines reach injection speeds up to 500 mm/s with dry cycles from 1.5 seconds. SPEED covers 128 to 468 tonnes, SPEED-PACK II 206 to 570 tonnes, and SUPER PACK 270 to 430 tonnes for the heavier thin-wall work. IML adds another constraint, since the robot needs mold open time to be short and, more importantly, identical every cycle. That’s a process stability question more than a speed question.
PET and Preform Production
PET needs low-shear plasticising to avoid yellowing and excess acetaldehyde. JM-PET/S2 and JM-PET/H use chrome-plated PET screws built for that, with high-rigidity clamping for large container tools. Caps and closures with a soft liner or a second colour move to multi-material machines, molding both materials in one cycle. Machine data and typical configurations are on the packaging injection molding page.
Back-to-School Demand: From Tumblers to Luggage, What Do These Products Require from Injection Molding? Meeting Back-to-School Demand with the Right Production Setup
Back-to-school shopping brings a familiar mix of plastic products into production, from insulated tumblers and pencil cases to lunch boxes and luggage. For manufacturers, the focus is not only on production volume, but also on maintaining consistent molding results across different applications. These are relatively mature molding applications, and standard Chen Hsong machine series can […]
Cap for 5-Gallon Water Bottle
Producing 5-gallon water bottle caps is a balancing act. Combining LDPE with TPE requires top-notch precision; any variation leads to seal failure, material waste, or costly contamination. We are seeing manufacturers in Colombia master this complexity using our JM168-DMIII multi-material solution.
Plastic Injection Molding of Large Paint Bucket
Paint Bucket In the above video, one of our clients is test running the JM668-MK6 to produce large paint buckets. Since this product is a fairly common one in the construction and household industries, and designs have been standardized over the years, manufacturers need to find ways to remain competitive by offering even shorter lead […]
Injection molding of 500ml plastic disposable food boxes
Disposable Fast Food Box 500ml In Shunde, China, one of our customers is employing our Speed Pack 400 injection molding machines to manufacture food grade lunch boxes made out of PP resin with a shot weight of 17g. The containers are transparent and an inner size of 500ml. The SPEED PACK thin-walled high-speed injection molding […]
Injection molding of plastic disposable food containers 830ml with Lid
830ml Plastic disposable food containers with Lid In Shunde, China, one of our customers is employing our Speed Pack 400 injection molding machines to manufacture food grade lunch boxes made out of PP resin with a shot weight of 42.8g. The containers are transparent with an attached lid and an inner size of 830ml. The […]
Injection Molding of Large PET Preforms At Maximum Yield
Large PET Preforms The inclusion of a high-quality PET mixing screw as a feature of our EM320-PET Toggle Type Injection Molding machine has enabled a customer to achieve a consistent yield of over 99% since 2016 in the manufacture of large PET preforms. In fully automatic mode, driven by Servo Drive and using the Beckhoff […]
Injection Molding of 20L Paint Bucket Lid in Polypropylene
Paint Bucket Lid In China, a customer in Foshan, Guangdong Province, has been using our new Mk6e injection molding machine series to manufacture various parts in polypropylene (PP). Each injection molding machine applies a clamping force of 320 tons, driven by our advanced Servo Drive and controlled by the CPC6.0 unit. In fully-automatic mode this […]
Wide Mouth PET Preform Manufacture Using the Specialist EM180-PET Injection Molding Machine
Wide-Mouth PET Preforms In Zhejiang Province, China, our customer has been employing 10 of our EM180-PET Toggle Type Injection Molding Machines since 2017 to manufacture polyethylene terephthalate (PET) wide mouth preforms. The EM180-PET Injection Molding Machine applies a clamping force of 180 tons with an Servo Drive power pack controlled by the Ai-02. A cycle […]
Employing the Focus 200 Injection Molding Machine to Manufacture Plastic Cups in Brazil
Disposable Plastic Cups In São Paulo Brazil at the FeiPlastic 2017 Event, we demonstrated how our Focus 200 Toggle type Injection Molding Machine can use 8 cavities to manufacture disposable polystyrene cups with a shot weight of 3.5g each, a thickness of only 0.5mm and a cycle time of 7.8 seconds in fully-automatic mode. The […]
Disposable Fork Injection Molding with Automatic Packaging
Disposable Forks with Automatic Packaging In Zhejiang Province, China, a customer has been employing 20 of our EM260-SVP/2 Toggle Type Injection Molding machines since 2016 to manufacture disposable forks in polypropylene (PP) in 36 cavities with a shot weight of 2.5g each and thickness of 1mm. In fully automatic mode, the EM260-SVP/2 Injection Molding machine […]
