Automotive Injection Molding Applications from Chen Hsong
Automotive injection molding at Chen Hsong covers bumpers, door panels, interior trims, lamp lenses, radiator tanks and under-bonnet components. BYD and FAW Group are among the manufacturers running Chen Hsong machines, with exterior body parts typically calling for 550 to 6,500 tonnes of clamping force.
Why Two-Platen Dominates Automotive Molding
A bumper mold is large, heavy and deep. Two-platen machines carry it in a shorter footprint than a toggle machine of equal force, spread clamping load evenly across the platen face, and give the daylight that deep draws need. Chen Hsong has more than 1,000 two-platen units in service worldwide. Lamp assemblies are a different problem again: a clear lens and a coloured housing molded in one cycle on multi-material machines, where rotary platen positioning accuracy decides whether the bond line comes out clean or bleeds.
Consistency Across a Model Programme
Programmes run for years, and process drift eventually shows up as a warranty claim. Precision Hydraulics™ holds ±0.05% repeatability on the critical axes, NON-STOP™ is built around uninterrupted running, and iChen™ AI Molder monitors and corrects parameters shot by shot rather than waiting for a technician to notice. More on the automotive injection molding solutions page.
Injection Molding of Volkswagen Car Door Panels
Volkswagen Car Door Panels A customer in Jiangsu Province is employing more than 50 of our Two-Platen SM1900-TP Injection Molding Machines as a trusted Tier-1 auto-parts supplier to prestige Volkswagen brands. Manufacturing Volkswagen polypropylene car door panels with a shot weight of 1,780g, at a clamping force of 1,900 tons, our customer is achieving a […]
Injection Molding of Automotive Side Panels Featured at ChinaPlas 2016
Automotive Side Panels At the international ChinaPlas 2016 expo in Shanghai, we demonstrated the versatility and precision of our SM700-TP Two-Platen Injection Molding Machines, powered by the SVP/2 Servo-Drive with the Beckhoff CBmold800 controller on an EtherCAT digital main bus, and generating a clamping force of 700 tons. The SM700-TP was employed to manufacture PP […]
Citroën Bumpers: Tier-1 Automotive Manufacture with the SM3000-TP Injection Molding Machine
Citroën Bumpers In Zhejiang Province, one of our customers is using two SM3000-TP Injection Molding Machines driven by the SVP/2 Servo-Drive and utilising a Beckhoff controller to manufacture Tier-1 parts for the prestige Citroën international automotive brand. The SM3000-TP is a Two-Platen arrangement with a clamping force of 3,000 tons and is working for our […]
ABS Injection Molding of Front Guards for Tier 1 Automotive Manufacturer Mazda
Mazda Front Guards In Zhejiang Province, a tier-1 supplier to legendary automotive manufacturer Mazda are manufacturing ABS front guards at a shot weight of 380g and thickness of 3mm with a cycle time of only 110 seconds in semi-automatic mode. They are able to achieve this by using our SM1900-TP Two-Platen Injection Molding machines, equipped […]
Injection molding Turn Signal Lamp Shades
Turn Signal Lamp Shades The JM168-MK6 plastic injection molding machines our clients are using for PMMA plastic injection deliver excellent quality in faster production cycles. Our client in Xinqian, Huangyan, Taizhou, Zhejiang is using nine of the JM168-MK6 injection machines to produce PMMA plastic turn signal lamp covers. The machines operate in semi-automatic mode and […]
Volkswagen Protective Panel Manufacture with the Two-Platen SM1650-TP Injection Molding Machine
Volkswagen Protective Guard A customer in Jilin Province has more than thirty of our Two-Platen SM1650-TP Injection Molding Machines operating continuously in fully automatic mode, manufacturing parts as a Tier-1 supplier for the prestige Volkswagen brand. Our SM1650-TP is powered by the SVP/2 Servo-Drive, controlled by the Nippobatta AI-12 system. A clamping force of 1,650 […]
Injection Molding of Audi Q5 Seat Construction Components
Audi Q5 Seating Fabric Over-Mould In Jilin Province, one of our customers is employing more than thirty of our SM1050-TP Two-Platen Injection Molding Machines to manufacture Audi Q5 seating fabric over-moulds as a Tier-1 supplier to this prestige automotive brand. Each SM1050-TP Injection Molding Machine has a clamping force of 1,050 tons, powered by the […]
Fully Automatic Manufacture of Volkswagen Door Panels With the SM1250-TP Two-Platen Injection Molding Machine
Volkswagen Door Panels Our SM1250-TP Two-Platen Injection Molding Machine features a clamping force of 1,250 tons, powered by the SVP/2 Servo-Drive, controlled by the Beckhoff CBmold800 system and employing an EtherCAT digital main bus. In this configuration, the superior technology we employ was demonstrated at the ChinaPlas 2015 convention in Shanghai. The SM1250-TP was used […]
Precision Injection Molding of Automotive LED Lamp Lenses
Lens for Automotive LED Lamps An example of the versatility of our Injection Molding Machinery can be seen in the application of our SM150HCV Direct-Clamping Injection Molding Machine, with a clamping force of 150 tons driven by the Delta Servo-Drive using the B&R SmartMold88 controller and a Powerlink digital main bus. Using 2 cavities and […]
