Power Outages in Injection Molding: How UPS & iChen Cloud Protect Production
Reading Time: 7 min
iChen Cloud Executive Dashboard
When the Power Goes Out, the Problem May Not End There
For injection mold manufacturers, a power outage can create challenges that continue after electricity returns. A UPS helps protect stored machine data during a power interruption, while iChen Cloud provides visibility into connected equipment and production conditions.
A production line is running as usual. Machines are processing parts, auxiliary equipment is working alongside them, and operators are monitoring the process.
Then the power goes out.
For manufacturers in some areas of Tunisia, this can be a recurring part of production. During the summer, electricity cuts can occur around two to three times a week in some areas, while temperatures can reach around 46°C during certain periods.
When the electricity disappears, the immediate problem is obvious. Equipment stops receiving its normal power supply.
But what happens when the power comes back? Is production ready to resume?
The answer may depend on more than whether the machine can be switched on again.
The Work That Begins When the Power Comes Back
Electricity may return in seconds. The work of checking and restoring the equipment can take longer.
After a power interruption, operators may need to confirm equipment parameters, check programmes and review production records before production can return to normal operation.
If stored information has been lost or needs to be restored manually, operators may need to spend additional time restoring the equipment before production can resume.
This part of a power interruption is easy to overlook because it happens after the event itself.
The machine may be receiving power again, but the production process still needs to be checked.
The question, then, is what information needs to remain available for production to resume.
For an injection molding system, this can include equipment parameters, programmes and production records.
What Does the Machine Need to Remember?
An injection molding system relies on this stored information as part of its normal operation. When the power supply is interrupted, protecting that information can make the recovery process more manageable.
One way to address this is to protect the information stored in the equipment. A UPS Battery can help with this.
A UPS Battery is used in injection molding systems to help protect equipment memory and stored information during a power interruption. In some factories, auxiliary equipment such as robots, dryers and feeding systems may also be connected to a factory-level UPS system.
Under normal conditions, the equipment operates with its regular power supply. When an interruption occurs, the UPS Battery provides temporary power to the controller, helping retain equipment parameters, programmes and production records.
The temporary power supply can also give the factory time to shut down the machine in a controlled sequence.
When power returns, the equipment can read the retained information. Operators can then use the stored data to check the equipment and manually resume production.
There is an important distinction here. The UPS Battery is not designed to keep an injection molding machine running during an outage. Its role is to protect the information stored in the equipment and support a controlled shutdown when the main power supply is interrupted.
The machine still needs its main power supply to operate. What the UPS Battery helps protect is the information that operators may need when that power returns.
What Can Manufacturers See After the Power Returns?
Protecting equipment memory addresses one part of the recovery process.
But once production starts again, manufacturers also need to understand what is happening across the production floor.
An injection molding operation can involve machines, robots, dryers, feeding systems and other connected equipment. Looking at each piece separately can make it harder to understand the wider production situation.
This is where iChen Cloud has a different role.
UPS Battery helps the equipment remember. iChen Cloud helps manufacturers see.
iChen Cloud connects injection molding machines and auxiliary equipment, allowing equipment status and production information to be viewed through a connected system.
It can also monitor UPS Battery status. Depending on the battery’s communication interface, information such as voltage, current, temperature, battery health and predictive alerts can be monitored. Customised development can also be supported according to customer requirements.
The connected view can also support everyday equipment management, including equipment records, inspection, maintenance and repair.
Beyond equipment management, connected information can also help manufacturers understand what is happening during normal production.
From One Interruption to Everyday Production Management
This visibility can also extend beyond equipment status and production information.
Production continues long after a power interruption has been resolved, and so does energy use across the production floor. Understanding where that energy is being used can be another part of day-to-day production management.
Through iChen Cloud, manufacturers can gain visibility into energy use across the plant, workshop and individual machine levels, covering electricity, water, gas and heat. Energy consumption, energy costs and idle or standby conditions can also be reviewed through the system.
This gives manufacturers a broader view of their production environment, connecting equipment operation with the resources used to keep production running.
The information collected through connected equipment can also help manufacturers understand everyday operating conditions and identify where attention may be needed.
Preparing for What Happens Next
Manufacturers cannot always control when a power interruption occurs.
They can, however, think about what happens before, during and after one.
Before an interruption, equipment information needs to be stored and available.
During an interruption, that information needs to remain protected, while the machine can be shut down in a controlled sequence when required.
When power returns, operators need to know what has been retained, what needs to be checked and what steps are still required before production can resume.
UPS Battery and iChen Cloud address different parts of this process.
The UPS Battery focuses on equipment memory, stored information and controlled shutdown. iChen Cloud adds visibility across connected equipment, production information, battery status and energy use.
Together, they address two sides of production management: protecting information inside the equipment and maintaining visibility across the production environment.
Conclusion
A power interruption can happen in a matter of seconds. The work that follows can continue long after the electricity returns.
For injection molding manufacturers, preparing for an interruption means considering what the equipment needs to retain, what operators need to check and what manufacturers need to see when production starts again.
A UPS Battery helps protect the information the equipment needs to retain and can support a controlled shutdown when the main power supply is interrupted. iChen Cloud helps manufacturers see what is happening across connected equipment and energy use.
When the power comes back, turning the machine on is only the first step. The production process still needs to be checked and brought back into operation.
Frequently Asked Questions
What happens to an injection molding machine during a power outage?
When a power outage occurs, an injection molding machine stops receiving its normal power supply. After power is restored, operators may need to check equipment parameters, programmes and production records before production can resume. Protecting stored equipment information during the interruption can help make the recovery process more manageable.
Can a UPS Battery keep an injection molding machine running during a power outage?
No. A UPS Battery used for equipment memory protection is not designed to keep an injection molding machine running during a power outage. Its primary role is to help protect stored equipment information, such as parameters, programmes and production records, so that this information remains available when the main power supply returns. It can also provide temporary power that allows the machine to be shut down in a controlled sequence.
How does a UPS Battery protect injection molding equipment?
During a power interruption, a UPS Battery can continue supplying power to the equipment’s controller. This helps retain stored parameters, programmes and production records. When the main power supply returns, the equipment can access the retained information, allowing operators to check the equipment and proceed with production recovery.
What is iChen Cloud for injection molding?
iChen Cloud is a connected equipment and production management platform designed to provide visibility across injection molding machines and auxiliary equipment. It helps manufacturers view equipment status and production information through a connected system, supporting day-to-day equipment and production management.
How does iChen Cloud help monitor injection molding machines?
iChen Cloud can connect injection molding machines and auxiliary equipment, allowing manufacturers to view equipment status and production information through a centralised system. Depending on the system configuration, it can support equipment records, inspection, maintenance and repair, helping manufacturers manage connected equipment.
Can iChen Cloud monitor UPS Battery health?
Yes. Depending on the UPS Battery’s communication interface and system configuration, iChen Cloud can monitor information such as battery voltage, current, temperature and battery health. It can also support predictive alerts and customised development according to customer requirements.
Can iChen Cloud help manufacturers manage energy consumption?
Yes. iChen Cloud can provide visibility into energy use at plant, workshop and individual machine levels. Depending on the system configuration, manufacturers can review energy consumption, energy costs and idle or standby conditions across connected equipment.
How can UPS and iChen Cloud work together in injection molding?
UPS and iChen Cloud address different parts of production management. UPS Battery helps protect equipment memory and stored information during a power interruption, while iChen Cloud provides visibility into connected equipment, production information, UPS Battery status and energy use. Together, they can help manufacturers protect critical equipment information while maintaining greater visibility across the production environment.
