Back-to-School Demand: From Tumblers to Luggage, What Do These Products Require from Injection Molding? Meeting Back-to-School Demand with the Right Production Setup
Back-to-school shopping brings a familiar mix of plastic products into production, from insulated tumblers and pencil cases to lunch boxes and luggage.
For manufacturers, the focus is not only on production volume, but also on maintaining consistent molding results across different applications.
These are relatively mature molding applications, and standard Chen Hsong machine series can generally meet the requirements of conventional products. The focus then shifts to matching the machine setup with the specific application.
Different Products, Different Production Requirements
Back-to-school products may sit on the same shopping list, yet they can place very different demands on the molding process.
For insulated tumblers, vibrant colour, plasticising performance and surface appearance are important considerations. Insulated tumblers have also gained popularity in European and North American markets in recent years. Common machine sizes for cup applications include 168T and 208T.
Pencil cases and lunch boxes place greater attention on colour quality, easy colour changes and surface appearance.
Luggage brings another consideration: part size. Depending on the product dimensions, clamping force requirements can move into the 500–800T range.
This is where application-specific machine selection becomes useful. Instead of starting with a machine model, manufacturers can first look at the product, production requirements, and mold setup, then determine the appropriate machine size and configuration.
What Matters Most in the Molding Process?
1. Color Quality and Easy Color Changes
Insulated tumblers, pencil cases and lunch boxes can all place a strong focus on color quality. For manufacturers producing different colors or product variants, easy color changes can also be an important consideration.
These applications are relatively mature from a molding perspective, so standard Chen Hsong machine series can generally meet the requirements of conventional products. For cup applications, 168T and 208T are commonly used, while 208T and 268T are common choices for boxes.
2. Plasticizing Performance and Surface Appearance
For insulated tumblers in particular, plasticising performance becomes another important consideration alongside surface appearance, especially where a high-quality finish is required.
3. Product Size and Clamping Force
Luggage brings a different consideration because of its larger part size.
Depending on the dimensions of the product, machine requirements can move into the 500–800T range. The appropriate machine size should therefore be determined by the product dimensions, mold requirements and required clamping force.
Across these applications, the MK6.6 and MK7S are recommended machine options. Other high-end Chen Hsong models can also meet the requirements depending on the application, product size and production needs.
Choosing the Right Fit for the Season
Back-to-school products may be familiar, but each application brings its own production considerations.
For tumblers, color quality and plasticizing performance can take priority. For pencil cases and lunch boxes, color consistency, easy color changes and surface appearance can shape the production setup. For luggage, product size and clamping force become a larger part of the equation.
The right machine choice starts with the product itself. Color quality, plasticizing performance, surface appearance and clamping force all play a role in determining the right production setup.
