Cap for 5-Gallon Water Bottle
March 19, 2026
Featured Machine: JM186-DMIII
Producing 5-gallon water bottle caps is a balancing act. Combining LDPE with TPE requires top-notch precision; any variation leads to seal failure, material waste, or costly contamination. We are seeing manufacturers in Colombia master this complexity using our JM168-DMIII multi-material solution.
The Reality of High-Precision Multi-Mat Molding:
- Flawless Material Bonding
Precise E502 thermal control ensures the LDPE and TPE fuse perfectly for a leak-proof cap seal. - Rock-Solid Stability
Patented tightening mechanisms maintain alignment even with heavy multi-cavity bottle cap molds. - Digital Injection Precision
EtherCAT-enabled control delivers the ±2% injection accuracy needed for consistent cap wall thickness. - Friction-Free Motion
Professional linear guide rails enable the high speeds required for high-volume cap production cycles.
Why the DM III?
Our Gen-3 technology utilises a servomotor-driven turntable for faster, more reliable positioning compared to traditional hydraulic systems. This ensures perfect quality for every single cycle.
