Plastic Injection molding of ABS Security Gate Frames
When injecting plastics for long flat items with narrow thicknesses, tolerances are of paramount importance in maintaining consistent product quality. The JM-1880-C2 plastic injection molding machine, with its clamping force of 1880 tons, delivers that absolute uniformity and maintains the production of high-quality products.
Our client in Huangyan, Taizhou, Zhejiang is using nine JM-1880-C2 injection machines to manufacture 1550x430x26 mm security gates. Each gate is 1.5 mm thick and is of ABS plastic construction. The dual cavity machine produces two gates per each 80 second cycle and each gate takes a shot weight of 1760 grams. With its Ai 11 Controller the JM-1880-C2 is run in semi-automatic operating mode.
- Model:
JM-1880-C2 Type: High-Speed Toggle
Year: 2010
Clamping Force: 1080 tons
Power Pack: SVP/2+ Servo Drive
Controller: Ai 11
Country: China
Number of Machines: 9
Part: Security Gate Frames
Resin: ABS
Cavities: 2
Dimensions: 1550mm X 430mm X 26mm
Product weight: 1760 grams each
Thickness: 1.5mm
Cycle Time: 80 seconds
Op Mode: Semi-automatic
