Setting up of SPA Condor Electronic’s New Factory Floor.
Scaling appliance production in Algeria means balancing massive output with tight overheads. Here are 5 ways our technology solves these daily manufacturing hurdles for SPA Condor Electronics.
- Deep-draw capacity vs. Floor space
Deep refrigerator tubs demand massive opening strokes, which usually requires machines that eat up valuable real estate. The SM1900-TP uses a true two-platen design to deliver the largest opening stroke in the shortest footprint. You get the capacity for massive molds without expanding your facility. - Sluggish cycles
Thick-walled refrigerator components dictate long cooling times, making every second of dry cycle critical. The MK6 recovers that lost time mechanically with 4.5s dry cycles at 1000T to keep production highly competitive. - Platen warping
Suspending heavy washing machine molds inevitably causes platen deflection, resulting in flash and uneven walls. The MK6 series utilises a patented circular platen design that actively distributes mechanical stress to reduce deformation.
- Cosmetic defects on displays
Molding clear or high-gloss engineering plastics like PC and PMMA for washing machine control panels requires flawless injection control to avoid flow marks. The MK6 PRO utilises silky-smooth linear guide rails and an advanced toggle design to maintain 0.01mm precision for perfect cosmetic yields. - Inconsistent parts
Slight dimensional variations in snap-fit appliance components cause havoc on automated assembly lines. The MK6 maintains a repeatability error of less than ±0.25% to guarantee uniform batches.
