Packaging Injection Molding Applications from Chen Hsong
Packaging injection molding covers thin-wall food containers, lids, caps and closures, cosmetics packaging, PET preforms, industrial containers and in-mold labelling. Cycle times under three seconds are normal here, and yield at speed is what decides whether a part makes money.
Built for Thin-Wall Speed
High-speed packaging machines reach injection speeds up to 500 mm/s with dry cycles from 1.5 seconds. SPEED covers 128 to 468 tonnes, SPEED-PACK II 206 to 570 tonnes, and SUPER PACK 270 to 430 tonnes for the heavier thin-wall work. IML adds another constraint, since the robot needs mold open time to be short and, more importantly, identical every cycle. That’s a process stability question more than a speed question.
PET and Preform Production
PET needs low-shear plasticising to avoid yellowing and excess acetaldehyde. JM-PET/S2 and JM-PET/H use chrome-plated PET screws built for that, with high-rigidity clamping for large container tools. Caps and closures with a soft liner or a second colour move to multi-material machines, molding both materials in one cycle. Machine data and typical configurations are on the packaging injection molding page.
Injection Molding of Make-Up Box Bases
Make-Up Box Base In Zhejiang Province, China, the JM178-Ai-SVP/2 Toggle Type Injection Molding machine has been proving its reliable operation since 2014 for a customer who is using 10 machines to manufacture ABS make-up box bases. With a clamping force of 178 tons, driven by the SVP/2 Servo Drive controlled by the Nippobatta Ai-02, our […]
High Speed Injection Molding of Disposable Containers with Applied Labels
Disposable Containers with IML The JM228-Ai (HS) High Speed Toggle Type Injection Molding machine is proving to be a very good choice for maximising throughput for disposable containers in polypropylene (PP) with integrated in-mold labeling systems. Powered by the SVP/2 Servo Drive and controlled by a Nippobatta Ai-12, each JM228-Si(HS) Injection Molding machine is able […]
Injection Molding of 20 liter PP Barrels for Chemical Use
20 Liter Chemical Barrel When a customer in Foshan, Guangdong Province, China, was looking for the ideal Injection Molding system for manufacture of their series of large 20 liter white barrels the decision to utilise our JM668-MK6 Toggle Type Injection Molding machine with excellent yield capabilities was an easy one. Powered by the MK6 Servo […]
Cosmetic Containers Manufactured in PMMA With the EM180-V Injection Molding Machine
Cosmetic Containers In Zhejiang Province, China, a customer has been using 10 of our EM180-V Toggle Type Injection Molding machines to manufacture cosmetic containers in PMMA since 2017. Featuring the VDP Power Pack and controlled by the Nippobatta Ai-02, the EM180-V is configured with a clamping force of 180 tons in this application, filling 3 […]
Fully Automatic Injection Molding of Acrylic Cosmetic Jar Lids in China
Cosmetic Jar Lids More than 40 of our EM180-V Injection Molding Machines are working full-time in Zhejiang Province to manufacture cosmetic jar lids. The EM180-V Injection Molding Machine is a toggle type with a clamping force of 180 tons, a VDP power pack and Nippobata Ai-02 controller. Filling 4 cavities with a shot weight of […]
Four Cavity Injection Molding of Cosmetic Jars in Acrylic Resin
Cosmetic Jars Our customer in Ningbo, Zheijiang Province has been employing over 40 of our Toggle type EM180-V Injection Molding Machines since 2016 in fully-automatic mode, manufacturing cosmetic jars in MS (PMMA) resin in 4 cavities, with a shot weight of 35g each. The cycle time is only 60 seconds, with the injection molding Machine […]
Injection Molding of Lipstick Cases for Global Cosmetic Packaging Industry
Lipstick Case for Global Cosmetic Packaging Industry Health and beauty industries rely heavily on plastic injection molding for the production of products needed in large quantities. Most of these products are single use and disposable items to prevent spread of germs and maintain sterility. When it comes to beauty items, plastic injection molding is the […]
Fully Automatic Injection Molding of Disposable Plastic Containers with IML
Disposable Plastic Containers with IML The single cylinder injection model SM200TSV Injection Molding Machine is a high-speed toggle type with a clamping force of 200 tons. It features a closed loop servo valve and direct-drive plasticizing motor. Driven by a Delta Servo-Drive via a B&R SmartMold controller and PowerLink digital main bus it is capable […]
High-Speed Injection Molding of Disposable Plates in Zhejiang Province
Disposable Plates For disposable plate manufacture cycle time is an important consideration for mass production. This is why our customer in Taizhou, Zhejiang Province, China, chose our SPEED258 High-Speed Toggle-Type Injection Molding machine, driven by the SVP/3 Servo-Drive and Nippobatta CPC 6.0 controller to maximize output. With more than 40 machines in continuous production since […]
High Speed Injection Molding of Disposable Cups
Disposable Cups Employing our Precision Hydraulics system, the SPEED 168 High-Speed Toggle Type Injection Molding machine demonstrates the possibilities for accurate, high-quality injection molding in PS with extremely short cycle times. With a dry cycle time of only 1.5s and full cycle time of 2.9s, throughput is maximised for high volume production. The SPEED 168 […]
