Left & Right Shroud Outer Plates
Injection molding left and right shroud outer plates for the automotive industry
Excellent uniformity and a superior finish are required on this automotive component and these standards are consistently met with the JM1450-C2 C2 plastic injection molding machine. Advanced technological innovations, an Ai 11 controller, and precise robotic operations are combined for the fully automated manufacturing of high-quality left and right shroud outer plates. 10 of these 1450 ton clamping force machines are in full time operation at our client’s facilities in the Changchun High-tech Industrial Development Zone.
With each injection of 956 grams of ABS plastic, the JM1450-C2 injection machine is producing both a right and left outer shroud plates in its two-cavity mold. Each shroud is 830 mm long, 265 mm wide and 75 mm high and the cycle time to produce a pair is 256 seconds.
Model: JM1450-C2
Type: High-Speed Toggle
Year: 2008
Clamping Force: 1450 tons
Controller: Ai-11
Country: China
Number of Machines: 10
Part: Left & Right Shroud Outer Plates
Resin: ABS
Cavities: 2
Dimensions: 830mm X 265mm X 75mm
Product weight: 956 grams each
Thickness: 3mm
Cycle Time: 256 seconds
Op Mode: Fully-automatic
Share this Case Study
